I have a stock 89 650sx which has always ran great. The last time a took it out it would run fine then just die. I could start it back up and run for a little then it would die again. Could this be a bad ground or a weak battery. It is a low quality walmart battery.
650sx cutting out
Re: 650sx cutting out
It certainly could be, or you might be siezing -hard to say without info. Did you test the battery voltage and do a compression test?SBT Tech Support is here to help with your problems.
There are many causes of seizure. If you see a drop in compression you will need to pull the engine and tear it down to determine the cause.SBT Tech Support is here to help with your problems.
