1996 gtx Oil block
  • 1996 gtx Oil block
    Quesion on the oil block kit? The 96 gtx has the oil pump mounted on the magneto cover, but is it still pretty much the same procedure as covered in the tech how to am i correct? Also which SBT part # is the correct kit for the gtx. thanks
    Re: 1996 gtx Oil block
    After the pump is blocked is it a good idea to stick with seadoo low ash oil (or equvilant), or can i use standard 2 cycle.
      Yes the procedure is the same. http://www.sbtontheweb.com/Merchant2...tegory_Code=36
      On that particular engine you can use any name brand synthetic.
        thanks again for the info.
