Greetings All,
I have a 1995 900ZXi which has been stored for five years. Before storage, the boat would fire the rear cylinder intermittantly out of a hole shot from idle then be ok after ten seconds or so. The only mod I've done is replaced the facory head with a "Cool Head."
Questions for the experts:
1. I would like to completely overhaul the carbs. What part kits will I need and are they available from SBT?
2. Can I, or somebody pre-adjust the carbs so that I can bolt-and-run?
3. Should I replace the carbs with others? I remember talk years back about the factory carbs leaving a bit to be desired.
Thank you for any help and suggestions offered!
