hi got a 951 it was playing up so i took it to get fixed no luck yet it was not running right and not revving out, the mechanic put a carby kit in both carbys it was no better then he cleaned out the rave valves the black things with the red plastic insert not sure what there called sorry and he turned the bottom screws on the carby out 1.5 turns as it says on your website now the idle is fine the trnsition is not right its like a flat spot between 3500 4500 revs after this transition period its fine although still only revving to 6000 revs with stock impellor it is kind of like a flat spot or a powerband on a motorbike but really dead in midrange any ideas i think its the adjustment of the rave valve
thanks
thanks
