I purchased a 96 xp last week. It turned over very slowly, and guy assured me that it just needed a new battery. When i put a new battery in, and it still turned over very slow, i pulled the plugs to see if less compression would let it turn over freely. Out shot brown murkish water, alot! I dumped what seemed like 5 gallons of water out of the engine, and started spraying fogging oil with a tablespoon of 2cycle oil in the cylinders and turning it over. Turned freely, no metal on metal sounds, but no spark to plugs. Opened the coil box, and it had several inches of standing water. I cleaned the connections and replaced the bottom sealed fuse (which was blown) and it fired right up. I put it on the hose to see if the cooling system was comprimised, and it idled fine for about 5 minutes. I then took it to the water and ran it for about 20 minutes. It would idle fine, and restart as soon as i pushed the start button, but every time I gave it throttle, it would choke out. If I feathered it slowly and got the rpms way up, it would run strong all the way to WOT. HERE is my question: what kind of rebuild do I need to do? the compression is 152 and 152, but surely the bearings and wrist pins need to be replaced. Does it sound like a carb rebuild is in order? maybe the jets are clogged? or the fuel system lines?
The guy I bought it from is going to pay 1/2 of a rebuild, but I need to figure out what I need and approximate labor. I bought it to sell, but don't want to sell somebody a ticking hand grenade.
Thanks for your help.
