Is there a block drain that I can use to flush the engine? The engine has sand and dirt in it. Flushing the normal way is not getting the engine clean. Someone stole the ski and now it over heats at idle.
Flushing FX140
Re: Flushing FX140
No. If the cooling system has been impacted with debris, you need to tear it down to get it clean, if flushing does not work.SBT Tech Support is here to help with your problems.
