Results 1 to 7 of 7
    Nov 2003
    detroit michigan
    3
    Post
    Bryan or glen,
    im sure one of you will be able to help me out. i have a 1996 yamaha waveraider 1100 and i want to drop a 1997 gp1200 engine into it. what are the differences between the waveraider 1100 engine and the 97 gp 1200 engine? they look exactly the same. is it just the bore of the cylinders or the stroke? what modifications would i need to make to drop a 1200 engine into my waveraider? if there isnt too much that i need to change i will probablly attempt this during the winter. thanks for your help
    21,555
    Post
    The 1200 engine has a larger bore and 3 pulse fittings while the 1100 has 1 pulse fitting. I believe the timing, flywheel, exhaust and carbs are different on the 1200.
    Nov 2003
    detroit michigan
    3
    Post
    thanks for the help. If i droped a 1200 engine in my machine would it fit? Also would i have to change all the electronics? i found a set of cylinders off a 1200 that have been bored for $125.00. Would this be a good idea to buy and put on mine?
    21,555
    Post
    Everything but the exhaust needs to be pulled over.
    Jan 2002
    586
    Post
    The GP1200 has a different timing curve for each cylinder. On the 1100 they are all the same
    Nov 2003
    detroit michigan
    3
    Post
    well it seems like i just have to keep my stock motor. I want to make it faster still. what are some of your suggestions? I blew the connecting rod on my engine. What would be the best route to take to repair my motor and get more speed out of it?
    Nov 2003
    spokane washington
    8
    Post
    Well my opinion would be, to start out with a fresh 1100, then do the mods on a fresh engine, the yami 1100 is one of the best engines made by yami, and most will not disagree. It is a very reliable motor and very simple to work on. No doubt more cc's mean more speed, but getting from point A to point B is more important. Build it yourself and take the time to learn the ski, in's and out's then when it breaks. you will know how to fix it........
  1. 1997 Yamaha WV 1100 w/ Blue Engine
    By tnlegendracer in forum Yamaha
    Last Post: 05-05-2006, 12:06 PM
  2. 1995 Waveraider 1100 w/bad engine and trailer
    By tucker13 in forum PWC's For Sale
    Last Post: 04-13-2005, 08:54 AM
  3. Replies: 0
    Last Post: 07-21-2004, 07:18 PM
