Hi, I have a 1994 gtx with a 650 and I also have a 1995 xp with a 720 engine. I would like to do a engine swap so I can use the 720 engine and its impeller with rew limiter from the 1995 XP on the 1994 GTX, and the 650 and its impeller with rew limiter from the 1994 gtx on the 1995 XP. I also plan to use the stator from the 650 on the 720, and stator from the 720 on the 650 because of the 4 and 3 wires diference to be able to match the electronics on the seadoos with out changing anything else. My question is, Am I in the right direction? is there anything else I should know like timing change or anything else? I want the 1994 GTX to go as fast as it can with what I have.
I have a seadoo engine aligment kit with engine mount shims and a SEADOO CLYMER manual. Any Ideas are fully apreciated. :emoticoni
