I have a '92 580 White engine with bad cylinders, and have two bored/honed cylinders from a '91 Yellow. Can I use these cylinders interchangably?
I measured the port timing on the white vs. yellow and they appear to be very close (from exhaust to top of cylinder is within 0.25 mm and from top of intake to top of cylinder is within 1.0 mm)
Everything else (water jacketing and port locations) is the same.
This will save me sleeving one set of cylinders if I can use the yellows on the white motor.
TIA!
TIA!
