Ski was running fine when put up over the winter. Tried to start it up for Spring and it will not start. Turns over and has spark but will not start. I was told it is probably the computer. I removed the computer. The case is a little corroded as is the plate it is mounted on but otherwise looks fine. I understand that the water connections to it are for cooling and there may have been an internal leak. Is this correct? Also, should the ski start out of the water without a hose attached?
