I just put a rebuilt 951 motor into my '00 RX and am getting a severe vibration. It's vibrating so bad that after only a few minutes it vibrated the exhaust bolts loose. Any suggestions on what may be causing this, and what to do to fix the problem?
Rebuilt 951 Engine Vibration
Re: Rebuilt 951 Engine Vibration
Disconnect the pump to isolate it to the engine - if it still vibrates, the counterbalance shaft is improperly installed - please call warranty for prompt replacement.SBT Tech Support is here to help with your problems.
