I have looked at the stock carb settings in sbt's tech section and its listed as 1 1/4 +/- 1/4 for the low speed but my manual say 2 turns out. Whats the better setting?
carb settings?
Re: carb settings?
Use the file attachment, not image tag to upload something from your hard drive - I removed your bad link.
I double checked the 1998 manual and yes you are right it does say 2 turns out that year, I was wrong - sorry!
Use the 2 turns out for your model.SBT Tech Support is here to help with your problems.
Re: carb settings?
The confusion about settings is because the 1998 white motors had smaller LSJ's than the 1998 grey motors. Depends upon wether or not your carbs have 180 LSJ's or 182.5 LSJ's in them.........
If you have carbs from a white motor, use 2 turns out as your starting point.
If you have carbs from a grey engine, use 1 3/4 turns out.Bill O'Neal <br>
