Riding today and it cut out, then ran rough. After checking the plugs, the middle one had the tip bent touching the electrode. Regapped, ran again, same problem. Need help with diagnosis. Thanks!
2001 Yamaha XLT 1200 bent spark plug tip
Re: 2001 Yamaha XLT 1200 bent spark plug tip
That is caused by debris - something is coming apart in your engine. Stop trying to run it or you risk more expensive repairs. Time to pull the engine and tear it down for inspection/replacement.SBT Tech Support is here to help with your problems.
Rod bearing failure, could be at the small end of the rod or the big end of the rod.SBT Tech Support is here to help with your problems.
