Motor: 717 Rotax
I Blocked Off On The Oil Tank The Original Feed To The Oil Pump (8mm Hose) Located At The Bottom Of The Oil Tank. The Other Outlet In The Bottom Of The Tank (12mm Hose), I Have Going To The Rotary Valve Side Of The Motor. The One On The Top Of The Oil Tank (12mm Hose) I Have Going To The Exhaust Manifold Side Of The Motor.
Question 1: Is This The Correct Gravity Fed Hose Configuration For The Rotary Valve Oil Bath With The Oil Pump Removed?
Question 2: Can I Use Pure Amsoil Synthetic Oil With My New Motor
For The Rotary Valve Oil Bath And As Well For My Fuel/oil Mixture?
Thank You Bryan (baltimore Md.)
