Hi I Am Wondering If Any Of You Can Help Me I Have Been Rebuilding A 1998 Seadoo Gsx Ltd I Have Nearly Compleated The Rebuild And Am About To Bolt On Some Second Hand Carbs I Aquired As Mine Were Seized. They Look Totaly The Same Apart From One Thing On The Original Set There Were Two Air Hose Conections To A Carb Solinoide Which As Far As I Can Make Out Has Two Lines Into The Air Box Two Lines One Two Each Carb And One Line To Vent?? What Dose This Solinoide Do? I Was Going To Fit Protec Flame Arestors Instaead Of The Standard Air Box And Again No Connections For The Two Air Hoses Can I Just Remove The Hoses And Will The Ski Run Ok With Out Them ? Or Do I Need To Use My Standard Air Box And Change The End Plates Over On My Carbs To Reconnect All Air Hoses ? Any Advice Would Be Apriciated Regards Karl In The Uk
