Okay let me get you up to speed.....
- 96 xp complete rebuild crankshaft, carbs everything
- New battery
- New Stalenoid (replaced after first trying to start)
- B/R are to the starter and others to the battery 1 red two black
* So after replaceing the stalenoids i got her to fire up even reved it a few times but now i get nothing, She wont turn over
- I replaced the spark plugs
- The high temp wires going to the spark plug are NOT getting a spark, I took one off and cut alittle bit off no luck then i took off the top piece (looks like an L) and attached physical metal petruding from the wire to a ground and no spark......Shouldnt i get a spark ther???
- one last thing the high temp sensor is kinda mangled would that cause this short among the circuit its just odd cause she started fine but i havent been able to since Thank you for reading please respond with anyhting im losing all hooooope!!! :(
- New battery
