Hi,
Having problems with my RH engine bogging/stalling when I open the throttle. Took off the flame arrestors and discovered that the accelerator pump either produces nothing, or gives a very weak spray. By contrast, the LH pump gives a robust squirt. Is this likely a damaged pump diaphragm? Sound like a carb rebuild required?
Thanks for your help.
-Brian
-Brian
