Results 1 to 2 of 2
  1. #1
    Joined
    Sep 2006
    From
    exeter, pa
    Posts
    8
    Default Removing Starter from 1998 TS770
    I have a 1998 Tigershark TS770, I believe the starter is bad. I traced power down to the starter when the start button is pressed. So I have disconnected the battery cable from the starter, removed both cap screws and ground cable. The starter is loose, however it will not come out. I read the DA__ book and I dideverything it said. Am I missing something? Is there some trick ? Pull up an inch twist to the left, and click my heels twice?? WHAAT ?? My biggest concern is it may be hung since the starter does not turn at all, the engine turns so the engine isn't frozen, but that starter will just not come out. Thanks for the help, Joeywang!!!!
  2. #2
    Joined
    Sep 2006
    From
    exeter, pa
    Posts
    8
    Default Re: Removing Starter from 1998 TS770
    Well I got it out. I used an old 1/2 drive extension and tapped on that from the front of the jetski with a smaller hammer. It took a couple of hits but it did come out. After getting it out and testing it, it appears the problem was the starter being hung up on something. When I put the starter back in and attempted to pull it out, it came right out. So I think my issue was the starter being hung. The ski now starts right up. Thanks, evrybody who read this I hope I helped somebody else out there. Joeywang:)
Thread Information
Users Browsing this Thread
Similar Threads
  1. Yamaha 800 Starting Help Needed.
    By Ericka-SBT in forum Yamaha
    Last Post: 05-16-2017, 10:17 AM
  2. 1998 Sea Doo GTX Starter Replacement
    By Yamahog in forum Sea-Doo
    Last Post: 01-29-2008, 08:23 AM
  3. removing the starter
    By stephanie in forum Sea-Doo
    Last Post: 05-29-2007, 05:35 PM
  4. SBT Incorrect Starter for 1998 GTX-RFI
    By Robert Willis in forum Sea-Doo
    Last Post: 07-01-2006, 09:01 PM
  5. 1998 gsx starter cuts off
    By fredgoc in forum Sea-Doo
    Last Post: 06-03-2006, 11:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
