Results 1 to 6 of 6
    Apr 2002
    California
    65
    Post
    What kind of material is the FX 140 hull made of?
    Is it a special fiberglass mix compared to regular boats or watercraft?
    What kind of material should I use to repair damaged hull?
    21,545
    Post
    It's SMC Sheet Molded Compond - it's repaired with marine epoxy kits.
    Apr 2002
    California
    65
    Post
    Thanks for the response.
    What is Sheet Molded Compound? How is it manufactured? How does Yamaha make the hull shape?
    How do you repair it?
    Marine Epoxy, is it different from polyester resin?
    Can you use the polyester resin with the marine epoxy? Which is stronger?
    21,545
    Post
    No you cannot mix the two. Repair procedures are almost identical. It's a mix of fiber material in epoxy instead of gelcoat and poly resin. It's drawn over the mold at high temp and vaccuum at the factory.
    Apr 2002
    California
    65
    Post
    To repair the hull I need to get fiberglass cloth or mesh?
    Then I grind out the spots then start filling back in hull in a series of steps?
    How many multiple times show I apply coats for holes that go all the way through the hull?
    I have multiple holes and severe damage to the hull.
    21,545
    Post
  1. MSX 140 Hull
    By janda930 in forum Polaris
    Last Post: 05-19-2005, 02:40 PM
  2. Water leakage at driveshaft thru hull
    By Dorman McLamb in forum Kawasaki
    Last Post: 07-24-2004, 11:58 PM
  3. Digging out potting material
    By skidogg77 in forum Sea-Doo
    Last Post: 07-23-2004, 09:06 AM
