I am in the process of removing and installing a block off plate for the oil injection pump of my 93 Seadoo XP. Going pre-mix after two engine rebuilds for hose failures. The directions say to leave the gravity fed oil line to block connected, but what do you do about the one that goes to the pump. Block off, or is it to go anywhere else? Thanks in advance.
Oil injection block plate install
Re: Oil injection block plate install
It's covered in the tech article - it gets plugged. Fold it over on itself and zip tie it, or zip tie a bolt in it.SBT Tech Support is here to help with your problems.
