99 ultra 150 starter wont shut off
  • 99 ultra 150 starter wont shut off
    So i have this ultra 150 which is a 99. Ive replaced mostly all of its parts, and i go for this long cruise on sunday threw the Long Island sound, and it ran great. Now as i pulled into the the harbor and shut it off ,this is where the problem started, the starter wont shut off, even if i hit the stop button.The only way it stops is if i pull the lanyard or turn the key off, anyone know wat might be causing the.
    Re: 99 ultra 150 starter wont shut off
    I had same problem on a 2000 150, the problem was the starter button, it was sticking (or weak return spring) and kept the starter running as well. pulling up on the starter button helped at first but it needed to be replaced.
