i have a 95 zxi 750 i was trying to order parts for but how do i know if it's big wrist pin or small..i'm trying to replace the the crank
need help
Re: need help
Remove the PTO and measure the diameter of the crank threads at the end as explained in the store: http://www.sbtontheweb.com/Merchant2...gory_Code=20-2SBT Tech Support is here to help with your problems.
Re: need help
2 strokes do not use case oil. It's lubed from the injection oil. www.howstuffworks.com has a good walkthrough on engines.SBT Tech Support is here to help with your problems.
