Results 1 to 3 of 3
Thread: SLT 700 miss
  1. #1
    Joined
    Aug 2007
    From
    Pittsburgh, PA
    Posts
    3
    Default SLT 700 miss
    My ski has a slight miss at lower rpm's, such as when it is on plane, but just barely cruising. I'm guessing around 20-30mph. It seems fine at higher rpm's but im not sure if i just can't tell then. I just put new plugs in it thinking that was the problem, it helped some but didn't fix it. Before i put the new plugs in i drained the gas tank completely and put fresh in before I ran it. My guess is that it is running a little too lean and is not getting enough gas. It tends to hessitate a second in midrange acceleration. Does anyone have any suggestions on how to correct this problem?
  2. #2
    Joined
    Aug 2005
    From
    wi
    Posts
    3
    Default Re: SLT 700 miss
    probably not a miss.
    especially if you are around 5000 rpm; very typical of a reed motor.
    however, make sure you are using the correct RESISTOR spark plugs.
    also, a cracked reed can cause a poor idle, low rpm miss.
  3. #3
    Joined
    Aug 2007
    From
    Vancouver, Wa.
    Posts
    8
    you could also have a bit of water in the carb diaphrams, i had this issue with my slt 750, had to remove the carb plates and clean out the diaphram area, and also replaced the dia's
Thread Information
Users Browsing this Thread
Similar Threads
  1. SLT 700 oil
    By adam250f in forum Polaris
    Last Post: 08-23-2007, 12:23 AM
  2. Polaris SLT 700 core differences SBT
    By drcasebolt in forum Polaris
    Last Post: 06-12-2007, 09:54 PM
  3. 1994 700 Slt
    By East Texas Pine Rooter in forum Polaris
    Last Post: 08-22-2005, 12:28 AM
  4. 97 SLT 700 & 96 SLT 780 FOR SALE
    By polaristriple in forum PWC's For Sale
    Last Post: 06-29-2005, 12:31 AM
  5. SLT 700 Problems
    By SLT700 in forum PWC's For Sale
    Last Post: 07-13-2004, 10:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
