i just both this 2004 GTX SC and it came with a full tank. I have taken it out
twice and finally filled the tank with fuel. I read the manual and it says recommended fuel is "Premium Unleaded" I guess that means 92 Octane right?
But it also says minimum is 87 Octane. So i filled it with 87 Octane rated. Well
took it out today and it wouldn't idle. It would die unless i give it trottle. So i figured two things:
1. I used the wrong fuel so going to syphon the 87 Octane out and use 92.
2. Just need to adjust the idle speed and be done.
My question is: The manual says 1800 RPM ( but it didn't say if its in the water or out) can anyone tell me what the idle speed out of the water?
Did my idle speed changed because i used 87 Octane instead of 92?
