Hello all. I could use some advice about my stock '94 GTX. I was riding this weekend at approximately 3/4 throttle when the engine bogged down and began feeling like something was caught in the pump. I soon realized that the issue was with the engine, not the pump. When starting the engine I can hear a "chirp-chirp-chirp" sound from the block. Once started, the chirp continues and turns to a loud knocking sound with any increase in RPM. At one point the engine did seize, but would restart after cooling down. At the advice of a friend, I pulled the plugs to check for any metal shavings, but did not see any. The oil lines are all in place (replaced this year).
I'm assuming (at minimum) I've fried a bearing. My current thought is to just pull the engine and replace it with a new SBT as that will give me a fresh start. At the same time, I don't want to spend $800 to fix a $200 problem. Should I have the current engine torn down or just go with the replacement? Reliability is extremely important. That's why I'm considering just replacing the engine.
Thanks for any help!
Scott
Scott
