I have a 2000 gsx rfi, when it is cold it will normally crank instantly and seems to run fine. Once it gets warm it will not crank. If you run it for as little as 30 seconds, cut it off and try to crank it again it is liable not to crank. If you run it long enough to actually warm up the only hope to get it to crank is to hold the throttle wide open and spin it over for a while it may eventually start. It has plenty of spark, but the plugs look wet when you pull them out after it will not crank. Any help would be greatly appreciated!!!
The fuel is fresh, the ski did sit for about a year. I drained the fuel flushed the system and refilled it. I did not replace the fuel filters as of yet.
The compression is 150 +/- on both cylinders with no leak down detected.
I have tried new spark plugs.
There is no water in the Fuel or Oil I have checked this
The battery is new and fully charged.
THANKS AHEAD OF TIME FOR ANY OF YOUR RESPONSES!!!
