'93 SL650 Carb settings
  • '93 SL650 Carb settings
    I have a '93 SL650 with sbt motor, your tech section does not list the carb settings for low speed and high speed. Yes I have the new style pump. Can you tell me what the settings are and if they are different for different cylinders why. It would seam that each cylinder would need the same amount of fuel under the same load conditions and RPM?
    Thanks for any help
