anyone know were the counter shaft oil drain plug is? manuel says oil should be changed every 50 hours with 30 wt oil i found the fill plug even though its hard to get to. it says its by the pto on the bottom i stuck my skinny arm under the eng all i feel is a bunch of bolts :emoticonl
97 xp counter shaft oil drain plug?
Re: 97 xp counter shaft oil drain plug?
#1 there is no drain plug.
#2 you don't change the oil - there is nothing to change. The oil is not in a sealed cavity, it was used after the first startup. Not sure what you are reading...SBT Tech Support is here to help with your problems.
Section 01 MAINTENANCE ( this what the manuel says :emoticonl )im confused
SPX, GSX, GTX and XP Models
On the 787 engine, remove the drain plug of the
counterbalance shaft located on the PTO side of
the lower crankcase.
Drain completely the crankcase oil of the counterbalance
shaft. Reinstall drain plug.
Remove the filling plug located on the upper
crankcase.
Add 30 mL (1 oz) of SAE 30 motor oil.
Reinstall filling plug.
All Models
Turn fuel valve to ON position.
Start engine; It may be necessary to use the
choke. If engine does not start, repeat previous
steps as necessary.
NOTE:If engine does not start after several attempts,
check ignition system for spark occurrence.
Refer to ELECTRICAL SYSTEM 07-02.
Check crankshaft if needed, it may be misaligned
or deflected. Refer to ENGINE 03-06.
After engine has started, spray BOMBARDIER
LUBE lubricant through air intake silencer while
engine is running.
1. Spray Bombardier Lube
Run engine until it reaches its normal operating
temperature.
-CAUTION
To avoid starting motor overheating, the
cranking period should not exceed 5-10 seconds
and a rest period of 30 seconds should
be observed between cranking cycles.
-CAUTION
Engine must be cooled using the flush kit.
F00M01A1
Maybe that was part of an old manual, not sure. Regarless, no need for it whatsover, you are fine.SBT Tech Support is here to help with your problems.
yah i think its a bunch of caka myself i searched for hours with my hands and cant find nothing .i know i did add oil once it was hard to fill and all it did was when i started it it smoked prety heavy for a while. well thanks for the info just wanted to know if anyone else changes there oil lol if so tell me about it:emoticonw
