Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Jun 2007
    Bloomington
    16
    Default Engine alignment question
    I'm getting so close to completing this project (installation of 657 into 94 GTX). I have the engine installed and connected and have been waiting on the arrival of an alignment tool. Unfortunately, Fed Ex delivered an empty box yesterday. The bar for the tool had slipped out of a hole in the end of the box. End result, I can't complete the alignment.
    Since the weather here in central IL is changing rapidly, I'd really like to get the break-in done this weekend. Would it be okay to just do the break-in with the engine not completely aligned? I've put the original shims back in place and the pump slides on with very little effort. Once I receive the rest of the tool I'll complete the alignment.
    Thanks for your help!
    Scott
    Sep 2007
    London, ON, Canada
    74
    Default Re: Engine alignment question
    **** that sucks. I wish I knew how to help you out...I was reading this post because I have the same question. I just haven't started my rebuilds yet.
    Aug 2004
    Olympia, WA
    3,629
    Yes you can, just be aware that you might cause damage....
    A trick to doing a quick alignment... Install everything, inlcuding the pump. Keep the bedplate a little loose on the mounts and kick the starter over a few times (don't start the ski). This will get you close. Then, tighten down the bolts...
    when you get the alignment tool, do it correctly. Also DO NOT forget those rubber peices on each end of the driveshaft... VERY Important, especially if your motor is not perfectly aligned.
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
    Jul 2007
    Jersey Sho
    27
    Quote Originally Posted by dsolie
    I've been debating on if I should go through of having someone align mine or rent a tool from sbt or a place like that. I went to go to a local shop and guess what the shop doesn't even have an alignment tool and the only person that knew what one was was the owner of the shop, and the place pulls motors all the time all they do is put the shims back in. That's exactly what everyone told me to do with mine but im picky with my stuff. What's the worst that can happen? kill the splines on the driveshaft, pto, and impeller? there's something wrong with my pump we put in a brand new double lip seal and it still leaks pump oil from the seal. errgh
    Aug 2004
    Olympia, WA
    3,629
    O-ring still on your pump shaft?
    Dan Solie -
    Sep 2007
    London, ON, Canada
    74
    One of my engines came already pulled from the boat, so I have no shims, nor do I have any idea how it was installed. I'll do the starter trick to get the thing aligned the best that I can. Does the shaft make a noise if it isn't properly aligned? How do you tell if it is aligned or not?
    1997 Speedster (twin 720s)
    London, Ontario, Canada
    Aug 2004
    Olympia, WA
    3,629
    Your PTO splines will strip in a few hours. lol That's usually the first indication.
    Dan Solie -
  8. #8
    Sep 2007
    London, ON, Canada
    74
    Well that's no good...I don't want that to happen.....hmmmmmmm
    I have to get some 2-stroke oil after work, I'll look into getting the proper tool.
  9. #9
    Sep 2007
    London, ON, Canada
    74
    So I borrowed the special tool from my local SeaDoo dealer. Wow they are cool. $40 cash, and they loaned it to me over night!! :D
    All set to go. Going to fire them up tonight. :D
  10. #10
    Oct 2007
    Key West
    198
    Nice job,
    You have to switch the hoses on the back of your engines, the hose with the T (flush hose) has to go to the headcover's arrow out, so standing behind the boat on the right hand, the single hose coming straight from the back (pump)has to go on the left hand site of the head cover(in arrow).
    On top of the flame arrestors, you see a little hole, there should be a plug in there, so water doesn't go in when you wash your engine compartment.
  1. When Is Engine Alignment Necessary
    By thunter01 in forum Sea-Doo
    Last Post: 08-11-2007, 05:25 PM
  2. 94 Monte Carlo 640 engine alignment
    By jvanick in forum Tigershark
    Last Post: 09-09-2005, 04:31 PM
  3. Engine Alignment Tool
    By 96XPCHRIS in forum Sea-Doo
    Last Post: 08-09-2004, 10:21 AM
  4. New Engine Order Question
    By Surovich in forum Sea-Doo
    Last Post: 08-08-2004, 06:53 PM
  5. Engine Mount & Alignment
    By cobrajoe in forum Sea-Doo
    Last Post: 09-07-2003, 09:10 AM
