Crankshaft run out
  • Crankshaft run out
    I just rebuilt my 1997 Daytona 1000 engine,it appears to run ok but there seems to be a lot of run out on the PTO end of the crankshaft ,it is possible to see the drive shaft floating bush oscillate when the engine is running
    What is a normal tolerance for crankshaft run out
    Re: Crankshaft run out
    Its possible to see it turning as it is pinched between the crank and the pto coupler. Run out is 0.05 mm or 0.002 in.
