try pulling out your needle valve and cleaning out the seat with some carb cleaner and put the needle valve back in. just be sure to remember how many turns you back out your needle. also try injecting some OMC engine tune into the fuel line while its running and let the smoke burn off before you shut it down. that should work for you.
