I have 2 2004 4 TEC models that I bought used. Both run great but one seems to have about 1-2 gallons of water drain out of it after about two days of operations, or about 2.5 hours of running per day. I noticed that the water is hot signaling to me it is coming out of the cooling system. These re loop cooled engines and there is no coolant in the water so it is not in the closed cooling sytem but somewhere in the heat exchanger set where there must be a leak. I am looking for suggestions on where to start looking...hoses, pump and intake connections etc. Any suggestions will help...thanks.
