i was checking my carbs on my 97 xp. to see if both carbs were geting fuel when i give it trottle.well when i give it gas when the engine is off looks like only the back carb is squirting fuel through the little brass tube just behind the choke butterflys shouldnt they both be squirting at the same time .i took all the lines out and used compressed air to clean the lines out even cleaned out the small fuel filter located in the front carb is this the way it supose to operate im use to automobile carbs :) does the front carb have a pump? i can only see the one on the back carb?
787 carb help
Re: 787 carb help
This is a very common problem and easy to fix. After removing the accellerator pump hose from the brass spray nipple in the side of the carbureator, grab the nipple with pliers or vise grips and twist and pull on it to remove the nipple from the carbureator.
Once you have it out, spray some canned brake cleaner into the fitting, then poke the check valve ball inside of the nipple with a small piece of wire to frree up the ball valve. Let it soak in some brake or carb cleaner for a few minutes.
Using a pop off tester to pump some air pressure into it, you can tell if the valve is releasing and working correctly. I have yet to find one I could not get working.Bill O'Neal <br>
Re: 787 carb help
Originally posted by Bill O'Neal2This is a very common problem and easy to fix. After removing the accellerator pump hose from the brass spray nipple in the side of the carbureator, grab the nipple with pliers or vise grips and twist and pull on it to remove the nipple from the carbureator.
