First time core exchange, all has gone good so far. I intend to boat all winter where temps often drop below 32 F. If I run the motor out of the water for short time will this be enough to winterize it? If not will rv antifreeze be ok. How and where would the antifreez be installed? Will fogging be required? How does one fogg?
Just replaced core on yamaha LS2000
Re: Just replaced core on yamaha LS2000
Any fresh water left in the engine will freeze, I'm not so familiar with the jet boats so search the forums for your application on familiar, also check on PWC today.com for info.SBT Tech Support is here to help with your problems.
