just want to know why do you have to fog a 4 stroke. i know it would prevent rust but its a four stroke its kinda like a motor cycle eng. can you just run it onece a month . wouldnt that be good enough? i was thinking because the engine block is full of oil all the time rather than a 2 stroke. were would the rust start forming piston walls?:beer
why do you have to fog a 4 stroke ?
Re: why do you have to fog a 4 stroke ?
No,you dont have to fog, the crank will have a coating of oil on it and if your not running it for a while then disconnect the battery and put gas stabilizer in the tank.SBT Tech Support is here to help with your problems.
