oil on piston
  • oil on piston
    hi, i have a seadoo sportster twinn engine. the left engine would not spin over so i pulled the plugs and spun in over. its sprays lots of oil out of the spark plug holes. can you tell me what might be wrong? thanks
    Re: oil on piston
    If the motor was not recently winterized.....Most likely you have a inner crank seal that has failed, and the oil is being purged from your rotary bath. This will most likely mean a crank replacement.
    depending on how much oil is in there after sitting for a day, you can still feasibly run the motor, as long as it's not too much oil... I had a ski a few years back, same problem. Ran great, but if it sat for a few weeks, the lower end would fill with oil... Cleared it out, started it up and she smoked for a while, but ran great! Your experience may vary..
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
