Fuel tank float
  • Fuel tank float
    Spoke to a couple people on here in regards to xpdi fuel gauge reading high and apparently there is a magnet in the tank that gets stuck and is why the gauge reads faulty, Anyone ever had the tank out of an 04 XPDI seems to look like a fun job.
    Re: Fuel tank float
    Pain in the *** Job. You must remove the motor to remove the tank, But you can get to the sending unit and the fuel lines by removing the seat. There is a black rubber plug under the seat that needs removing and then your in.
      Re: Fuel tank float
      So for that job would i have to remove the motor cause if im ganna do that i mite aswell put a steering cable in it aswell but when i remove the seat will the sender unit come out from the top.
        Re: Fuel tank float
        No the sending unit will pull out through the rubber plug.
          Re: Fuel tank float
          Weres the fuel filter then is it in the tank or on the outside.
            Re: Fuel tank float
            Its on the bottom of the sending unit, You should replace it while the sending unit is out.
              Re: Fuel tank float
              Cheers mite give it a crack first i have to sort out this missing problem.
