i have a problem with a 550 kawi. the engine won't turn over very well until i take the spark plugs out. with the plugs in the engine turns maybe 1/4 turn then stops. what the ??? after that it has spark and a good battery. the ground and positive cables appear to be ok. could this be a bad starter? also nothing stuck in pump. :emoticonc
kawasaki 550 starting problems
Re: kawasaki 550 starting problems
Could be a bad starter or a break down in the positive or negative cables for the battery or the starter.SBT Tech Support is here to help with your problems.
