New engine, no power to guages..HELP!
  • New engine, no power to guages..HELP!
    I recently got a new engine and ut it all in the 2000 XP. when we put it in, the timing was off and backfired a few times. we know the timeing problem now but when we put the key on, no beeps, no guage movement, no power NO NOTHING!. need help. battery is good and i have power to main box. I need some suggestions with this!
    Ken Folsom
    2008 RXP-X 255
    2003 GTX DI & 2003 GTI LE
    2000 GTX RFI Millenium Ed.
    1990 Mastercraft 191 - Ford 351 Windsor GT40
    Team Mastercraft
    USA Waterski - 2003 KD CR7
    Re: New engine, no power to guages..HELP!
    Well, we found the problem. One fuse was blown. We jus didnt know they were right there! and as for the timing problem, MAKE SURE THE CUP IS ALLIGNED ON THE FLYWHEEL! but all is well. All needed now is an idle adjustment and break in? anyone know how long break in period on the SBT engine is?
    Ken Folsom
    2008 RXP-X 255
    Team Mastercraft
      Your first tank should be fine, vary speed on the ski and dont run wide open for any extended time untill you use up the 1st tank.
        OK. well in south alabama, its easy to go out on the river in march so as soon as the wind dies down, ill see how it goes. All seems well for the minute i ran it on the hose so I just need to set the idle and adjust everything. Also, should i run premium fuel or just regular unleaded?
        Ken Folsom
        2008 RXP-X 255
        Team Mastercraft
          Its always good to run higher octane, but thats up to you.
            I used fuel stabilizer in this tank as it has sat for about 2 mongth. I drained what was in the lines when i pulled the carbs. No bad smell but should i worry with dumping the tank as I used stabilizer and treatment, or just see how it runs?
            Ken Folsom
            2008 RXP-X 255
            Team Mastercraft
              Two month old fuel is fine. Use it. If it sat for 6 months I would say get rid of it.
                ok...so I am trying to get the final assy done as in the small engine accessories......any suggestions? I cannot get the bottom to line up and the prots on the carbs. I know it has to slide on the pin down bottom but i can't seem to get it to line up right......any suggestions to an easy way to get it go on?
                Ken Folsom
                2008 RXP-X 255
                Team Mastercraft
                  Uhhh.. What are you trying to install?
                  Dan Solie -
                  04 RXP (the "Instigator")
                  94 xp (freestyle mods)
                  95 xp (faster than the 94)
                    I think he is trying to install the carbs on the intake? The little pin that lines the carb on the intake manifold is that it, if so dont force any thing take your time and work slowly on it.
                      Ahhh okay.. A few posts up all he said it needed was an idle adjustment.. I assumed that meant the carbs were already installed.
                      Do you have the top plate attached to the carbs? It makes installing them as a pair a lot easier. Just run the 4 carb bolts down and match them to the intake area, thread in a few turns, and the carbs should then slide right down the bolts onto the intakes (you did install new gaskets, right?).
                      Are you re-installing the stock airbox as well?
                      Dan Solie -
                        sorry about that, I thought i added i was putting the breather on. I have the carbs on,a nd it is running fine. I just have to put the STOCK airbox on and then the breather atatchments. I know the bottom of the airbox has to line up on the pin by the starter but i can't seem to line it up correctly to the pin and the carbs.
                        Ken Folsom
                        2008 RXP-X 255
                        Team Mastercraft
                          ok.....so i found the problem....the mount is on backwards. I thought i had already checked that because we checked on a diagram before but i guess it was wrong. Now the question is...Do i pull it off and flip it or do something else to the breather?
                          Ken Folsom
                          2008 RXP-X 255
                          Team Mastercraft
                            Pull it off and install it the correct way.
                            • #15
                              We flipped the mount, installed the airbox and breather attatchments and all looks good. I ran it for a minute on the hose just to crank it and al sounds good. I am taking it to the river today to break it in to see how she runs.....I'll let you know how it goes... THANKS FOR ALL YOUR HELP TECH SUPPORT!
                              Ken Folsom
                              2008 RXP-X 255
                              Team Mastercraft
