Ski is new to me but is a 97 1200. how do u do an oil change on this. does any one know what the zert fittings on each side of the heads do(there mounted to the carb plate). I know they have hoses hooked to them that go some where.
oil change
Re: oil change
Fitting is to grease the drive coupler, Its a two stroke, you dont change oil. Make sure you keep the oil tank topped off each time before you ride.Two strokes have oil injection and it mixes oil with the gas for lubricating the engine so it will use oil while riding.SBT Tech Support is here to help with your problems.
