Results 1 to 6 of 6
    Mar 2008
    houston
    3
    Default yamaha wave raider stalls during left turns
    My yamaha 1100 wave raider loses power and almost dies when I make a hard left turn. Seems to be starving for fuel. Recent sbt shortblock installed. Otherwise has a lot of power. Any ideas?
    21,555
    Default Re: yamaha wave raider stalls during left turns
    Did you replace the motor and not re build the carbs?
    Mar 2008
    houston
    3
    No I did not rebuild the carbs.
    21,555
    You have committed the ultimate sin in the watercraft world, Never replace the engine without going through the carbs. It sounds like you are running lean do to a restriction some place in the fuel system. Start by removing the carbs and opening them up to inspect. What happen to the first engine to make you replace it?
    Mar 2008
    houston
    3
    Quote Originally Posted by Technical Support
    The front piston ring came loose and ruined the cylinder head and piston and scored the cylinder.Crankcase was full of debris. I did not own it at the time it happened. Only has 100 hours on it. I suspect it had something to do with oil injection. I switched to premix.
    21,555
    You need to rebuild the carbs, It sounds like its leaning out. And that is more than likely how it failed the first time. Dirty fuel systems and water ingestion are the #1 cause of engine failure.
  1. Yamaha Wave Raider Impeller
    By bjc323 in forum Yamaha
    Last Post: 10-06-2016, 03:26 PM
  2. 96 Yamaha Wave Raider Hard to Start
    By jsheidler in forum Yamaha
    Last Post: 04-17-2006, 08:36 PM
  3. 1996 Yamaha Wave Raider 1100 Jetski W/Trailer
    By TheEdge in forum PWC's For Sale
    Last Post: 01-01-2006, 04:54 PM
  4. 95 and 96 Yamaha wave Raider 1100's
    By corvettester in forum PWC's For Sale
    Last Post: 06-01-2005, 09:33 PM
  5. For Sale - 1994 Yamaha Wave raider 701
    By Ramtour2 in forum PWC's For Sale
    Last Post: 06-27-2004, 01:28 PM
