Reed valve has a seal where box fits in block, looks like a o ring. Is this something special or just a o ring and where can I find them if special.
99 genesis reed valve
Re: 99 genesis reed valve
The seal is part of the reed cage, Put gasket sealer around the reed cage surface then reinstall. Make sure every thing is nice and clean before you re assemble it.SBT Tech Support is here to help with your problems.
