Polaris slx 780 95&96 H&L speed screws?
  • Polaris slx 780 95&96 H&L speed screws?
    I need to adjust the high and low speed screws. Please advice on best way to do this. Thank you!
    Re: Polaris slx 780 95&96 H&L speed screws?
    low speeds are closest to the base of the carb, 1/2 turn out from seated ( all ). High speed are closest to the air box, mag end is 1 turn out , middle is 1/2 out and pto end is 3/4 out. Tom sbt tech.
      I was told I don't need to remove these screws when doing a carb kit. The carb did have alot of gum inside. Can I dip it in carb cleaner without removing these screws and get a good result? Thank you.
        No take them out and clean them, replace the o-rings on the. Tom SBT tech.
