Im trying to get my 96 sea doo xp up and running for the season and every time I try to start it all I get is an alarm that sounds three times and the oil light flashes. It will not turn over or start at all??? anyone have any idea as to why this may be happening?
Sea doo xp alarm 3 times
Re: Sea doo xp alarm 3 times
You must get two quick beeps for the ecu to recognize the key, if not it will not start. The key might have to be re-programed. Tom SBT tech. The other issue is your oil sender is giving a no oil fault, check oil level sender.SBT Tech Support is here to help with your problems.
Its located in the oil tank, Send me your fax # and I will send test info. tom@sbtontheweb.com.SBT Tech Support is here to help with your problems.
I just realized that it is not the oil light that is flashing when i push the start its the high water temp light. I get the two beeps for the key req and then when i push the start I get three fast beeps and the high water temp light flashes three times with it???
Any ideas?
