Results 1 to 2 of 2
    Jun 2007
    So Cal
    3
    Question Can I use a carb cleaner (like seafoam)?
    Sorry if this sounds stupid, I just dont wont to kill my engines.
    Can I use a carb cleaner like Seafoam on my Yamaha 2000 GP1200R?
    If I can is there something better? The engine still runs pretty strong.
    Also, I have a very hard time starting it after a few months of non-use.
    What is the best way of getting it started again (I am currently using starter fluid sprayed into the spark plug holes).
    Thank you
    21,545
    Default Re: Can I use a carb cleaner (like seafoam)?
    Starter fluid WILL DESTROY a two stroke, It has no lubricating ability, sounds like you could have a fuel line sucking air or its time to rebuild your carbs. But stop using Starter fluid. WD 40 will work as starter fluid and has lubricating abilities. Tom SBT tech.
  1. carb troubles.
    By SubmarineAZ in forum Yamaha
    Last Post: 11-21-2007, 11:40 PM
  2. Carb cleaner - Fuel additives question?
    By jasno999 in forum Yamaha
    Last Post: 07-06-2005, 09:23 AM
  3. Carb Rebuild Gone Bad
    By JimZ in forum Sea-Doo
    Last Post: 09-13-2004, 04:52 PM
  4. Best carb cleaner
    By hybris in forum Sea-Doo
    Last Post: 06-07-2004, 03:03 PM
