Hi All, as the post states, my Rave valves are leaking on a brand new SBT 787. I finally got this machine running flawlessly (save for raves) yesterday. I am running oil injection as well as SBT break in oil, and finished one tank of gas yesterday. As per the pics, the raves are leaking and exhibit a oily residue on the rave bellows. Any help in understanding this phenomenon would be greatly appreciated.
New SBT 787 engine...leaking Raves
Re: New SBT 787 engine...leaking Raves
Are the bellows screwed all the way down on the piston of the rave? Were new gaskets installed?
I would pull the bellows off and make sure the lower spring is still in tact and has not slipped.Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
The black goop is unburned fuel. My new 787 engine did that too for awhile. It seemed to get better after break-in. Dan gave good suggestions. Assuming the bellows are good (you have the green ones I hope), also check the rubber o-rings on the Rave shaft. They should be pliable, and I would replace them if they haven't been changed in awhile. Make sure plugs are relatively fresh and if you are running oil injection, double-check oil pump adjustment. Also less likely, it is possible your carb could be in need of a rebuild (primarily needle and seat) or simple adjustment if it is running too rich.
When you bought the SBT engine, the valves should have been on the engine, if so, contact them before you start taking things apart, you do not want your warranty to be void, they might tell you to take them from the engine and send them to them. Have SBT tell you what to do.
Rave valves should not be leaking, also not during break in.
Send Me an email and we can go over some options. Tom. tom@sbtontheweb.comSBT Tech Support is here to help with your problems.
Sent an email today to SBT regarding the latest leaking raves. Phoned a few weeks ago, and shortened the bellows springs as per SBT tech. Made things worse!! Still after 3 PM's have I have never had any response from Tom. I hope I'm the minority in falling through the cracks of service challenges.
Originally posted by tippy View Postsent An Email Today To Sbt ... Still After 3 Pm's Have I Have Never Had Any Response From Tom. I Hope I'm The Minority In Falling Through The Cracks Of Service Challenges.John Kubiak
Las Vegas, Nevada
Sea-Doo Tech 13736
Tippy, as per our conversation on Monday, I had not received any emails directly to my address, we are sending to you two complete sets of rave valves to solve your issue. We have experienced some delays on response to our web site due to up dating our server, sorry for any inconvenience. Tom SBT tech. In the future if you don’t receive on line info fast enough, then please call us on our toll free line and ask for the tech department.
