HELLO SBT.
I AM CALLED ELOY And I BEEN OF SPAIN And I NEED INFORMATION
TO ANSWER A PROBLEM OF MY YAMAHA WAVERUNNER GP 1200 Of The 99.
I MUST SAY THAT NOT TO BE SPOKEN To MUCH ENGLISH And USE A TRANSLATOR (IF TO BE ABLE TO SEND The ANSWER To ME IN SPANISH I THANK To YOU).
MY PROBLEM IS: IT IS VERY DIFICULT TO ME START UP YAMAHA GP1200. IF I DEPOSIT OF The GASOLINE THIS PLENTY LESS WORK COSTS To ME TO TAKE YAMAHA GP1200 And IF I DEPOSIT OF GASOLINE IS BELOW HALF, IT With Himself NOT TO ALMOST START And WHEN IT STARTS IT DROWNS UNTIL IT DOES NOT BEGIN TO TAKE
SPEED (TO OBTAIN I NEED IT TO GIVE the ACCELERATOR And TO LOOSEN IT SO
THAT IT CAN TAKE To SPEED The YAMAHA GP1200 And THAT IT IS NOT STOPPED
To ME).
A GREETING And I WAIT FOR YOUR ANSWER AS RAPIDLY AS POSSIBLE MY MAIL
IS: YGP1200@YAHOO.ES .
GOOD BYE
ELOY SERRANO
MI PROBLEMA ES: QUE ME CUESTA MUCHO ARRANCAR EL MOTOR DE MI MOTO DE AGUA, ESTO NO SOLO ME PASA AL PRINCIPIO DE UTILIZAR LA MOTO, SINO CONTINUAMENTE.
HE OBSERVADO QUE CONTRA MAS VACIO ESTA EL TANQUE DE GASOLINA MAS TRABAJO ME CUESTA PONER LA MOTO EN MARCHA. ADEMAS CUANDO TIENE POCA GASOLINA AL CONSEGUIR ARRANCARLA, TENGO QUE IR DANDO GAS Y SOLTANDOLO HASTA QUE EMPIEZA A ANDAR PORQUE SINO SE ME AHOGA LA MOTO.
ES COMO SI LE COSTASE MAS CHUPAR LA GASOLINA CONTRA MAS VACIO ESTA EL DEPOSITO DE GASOLINA.
ME HAN DICHO QUE PUEDE SER DEBIDO A QUE ESTEN EN MAL ESTADO O HAYAN CEDIDO ALGUNAS MEMBRANAS (GASKET) DE DENTRO DEL CARBURADOR.
[ June 25, 2004, 02:08 PM: Message edited by: Technical Support ]
To ME).
GOOD BYE
ELOY SERRANO
