Has anyone ever heard of the water jackets around the comp.dev a crack alowing water to go into the comp in turn injecting it into the fuel system causing ski not to run at full rpm .Eventually locking the moter up.
2003 gtxdi compressor problems
Re: 2003 gtxdi compressor problems
I have heard of water getting into the compressor, thus cauing the compressor to throw a rod and causing some major issues. I don't think there would be enough water coming through the compressor to lock up the motor..
What problems are you having?Dan Solie -
04 RXP (the "Instigator")
94 xp (freestyle mods)
95 xp (faster than the 94)
Ski would not run but 35 mph tac 5350 i took it to dealer hooked up buds no codes in it .Cleaned rave vales tried new fuel pump,injectors,exhaust he could never figure out what was wrong with it. He keep telling me the ski ran to good up to 35 I know this mech was frustrated .finally he calls me after about 6wks tells me comp has water in it. Moter needs to be relaced.I run a trucking co i know a little about moters so i ask where's the water coming from ?he tells me block cracked around comp now the moters locking up.I say BS i think he blew it up.It has never run hot with me. In the shop i have never seen them hook water up while running a ski. Ski is still at dealership dont know what i should do here really.
If he means the crank case with block, hmmmm that is not cooled in that area, the compressors head has the cooling sytem to it and is a romovable part with just 3 bolts.
After a ski has been sunk, there can be water in the air feeding hose coming from your throttle bodies.
Anyway, take the compressor head off, remove fuel line, two water lines, and the air in line.
Clean all lines, inspect the head, gasket etc, make sure that the cooling lines are not glogged on any side.
What fuel pressure are you getting?
The same way you check your fuel pressure BUT now with the fuel pump disconnected checks your compressor, see a shop manual for the specs.
Yes make sure that the compressor is bone dry or your ski will run like you are saying.
However as far as I understand your engine is toasted at the dealer.
Bummer
曾道人白小姐天线宝宝等所有资讯
香港六合彩彩开奖结果 香港六合彩期开奖结果 香港六合彩票开奖结果 香港六合彩的开奖结果 香港六合彩、六合彩资料、六合彩图片和六合彩特码资讯,只应用在合法的香港六合彩特码资料探讨,暂不适用于其它非法的六合彩特码资 料资讯,外围博彩和非法使用。如引为他用后果自负。本网概不负责。如因本中心所引起的所有民事诉讼均或相关 均与本六合彩公司无关,香港六合彩图库提供所有六合彩特码信息仅供数理研究之用,任何人不得用以赢利!!本 站 所服务范围:六合彩图库、六合彩特码、六合彩图、六合彩资料,六合彩开奖记录、 香港6合彩十二生肖.黄大仙论坛救世报射箭图,天线宝宝,管家婆.报码聊天室.惠泽社群,六合采彩.免费图 库.六合彩开奖时间,马会挂牌,六合彩开奖结果、香港六合彩图库,6合彩,六和彩,六合采,六合,六和彩, 香港六和彩,香港六和彩公司,liuhecai,六合彩一码中特、单双中特、六合彩免费图库、金多宝之脑筋 急转弯、平码三中三,曾道人白小姐天线宝宝等所有资讯只为搜索引擎排名与学习研究之用
