Results 1 to 1 of 1
    Lightbulb Changing Batteries
    The SBT tech department recommends when removing and installing a watercraft battery that this procedure be followed. Removing: disconnect the negative cable first then the positive. Installing: positive cable first and then the negative cable. Any time you charge a watercraft battery, you should remove it from the watercraft and place it on a work bench to charge using nothing larger then a 2 amp charger. Remember to loosen the vent caps on the battery while charging.
    Ericka Buczkowski
  1. Carburetor check on new install or Rebuild
    By Ericka-SBT in forum Tech Tip Of the Week
    Last Post: 09-19-2008, 12:45 PM
  2. Fuel Injected motors.
    Last Post: 09-04-2008, 05:04 PM
  3. Repair Manuals
    Last Post: 08-29-2008, 04:00 PM
  4. Tech Recommendations (in Texas) Wanted
    By Sea. Sea. Ryder in forum Yamaha
    Last Post: 09-29-2001, 12:02 AM
