95 XP800 no start, fuel and battery lights stay on
  • 95 XP800 no start, fuel and battery lights stay on
    so far put a new battery and starter relay in it.
    all fuses are good.
    when i hit the start button the lights all come on (like they're supposed to?) but nothing.
    the fuel and battery lights stay on even when i take the key out.
    do i need an MPEM or CDI or something?
    Re: 95 XP800 no start, fuel and battery lights stay on
    Is there a "click" when you push the start button from the relay?
    When you put in the key, does it beep at you? how many beeps?
    Dan Solie -
    04 RXP (the "Instigator")
    94 xp (freestyle mods)
    95 xp (faster than the 94)
      Dess post/coded key was an opion that year, if this is what you have then the post it self may be bad and would need replacing.
        no beeps
          well, if you have a DESS post and no beeps, I would replace the DESS post.
          Dan Solie -
            to test for a bad post could i just jump the wires on the back?
              No, that will not work, the posts do go bad.
                is the post plug n play, or is programming required? thanx for all your help so far. maybe i will stick around and not sell this pos now.
                ....................... if it runs.
                  Plug-n-play..
                  Please describe your post... does it have a plunger on it? Or is it a solid piece with a metal dot on the top and a metal ring?
                  Dan Solie -
                    solid with metal dot and ring i am 90% certain
                      It is a coded system.
                        o.k. so it is not plug n play? :(
                          Your key holds the code, The dess post is just a switch to send the code to the computer to start the machine. You might just have to replace the dess post so it can transfer the keys code to the computer, at that point you will hear 2 beeps and the code is recognized and the ski cranks over.
                            well i just bought the whole front box with post and dess key, so we will go from there...
                            • #15
                              well, do yourself a favor and just replace the post first when the new box comes in.
                              Dan Solie -
